New cam but no 12's
Old Apr 10, 2007 | 04:46 PM
  #16
Capn Pete's Avatar
You can use ANYTHING from '93 - '02 ... your best bet is just using factory 16's w/ 255/50/16 DR's .
Old Apr 10, 2007 | 06:43 PM
  #17
SSpdDmon's Avatar
Tires and tune - definitely.
I wouldn't advise running heavy or wide open until then too. You're probably running considerably lean (not good). Timing will be close given you have a '98. But, there'll be some power to pick up between 4,000 & 5,200 RPMs. Given those two things (AFR and timing), it's no wonder you're turning 13's on street tires.
As for the tires, you should be fine as long as you're sensible about it (ie no 5500rpm clutch drops after you warm 'em up).
Old Apr 10, 2007 | 07:34 PM
  #18
Greed4Speed's Avatar
Originally Posted by reamo04
Put on a TA girdle for the rear, and that should help prevent breaking your rearend.
Sure it will.
Old Apr 20, 2007 | 07:36 PM
  #19
IrocSS85's Avatar
6500 sounds a little high to me for a 224 cam'd car. what gears do you got? stock 3:42's? lower control arms and air bags for the back and you should also disconnect the sway bar end links to help the car transfer more weight to the rear tires.
and, are you spinning badly and thats why only 2.1x sixty? or launching softly? how are you launching and how is the car reacting?
and get a tune already.
Old Apr 21, 2007 | 10:02 PM
  #20
1LE4ME's Avatar
I'm pretty sure the bad times are coming from a slipping clutch. Time to replace it.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
