Motor mounts
Old Nov 23, 2003 | 10:17 AM
99BlackZ28T56's Avatar
Motor mounts
Where can I buy poly mounts for the motor? I'm installing LT's soon and would like to keep the movement of the engine to a minimum.
Old Nov 23, 2003 | 07:28 PM
8850's Avatar
Steve at www.spohn.net has them for $39.00/pr. He carries Prothane 7-508.
Old Nov 23, 2003 | 09:17 PM
I only see solid motor mounts and poly trans mounts. I searched the part # and at BMR Fabrication 7-508 is for LT1, 7-512 is the LS1 and both are $59 each pair.
Old Nov 24, 2003 | 06:55 AM
8850's Avatar
That could be the wrong part number but check this post out. Steve said he has them for $39.00 for LS1.
http://ls1tech.com/forums/showthread.php?t=116223
Old Nov 24, 2003 | 12:18 PM
8850's Avatar
The correct Prothane number for LS1 is 7-512.
Old Nov 24, 2003 | 06:37 PM
teke184's Avatar
how much do these mounts keep the motor from torqueing up? i'm having trouble with my orp hitting my frame, maybe the poly mounts will keep some of this to a minimum.
any help in this area?
Old Nov 24, 2003 | 09:18 PM
I've seen several post that this solved the headers/ORY banging or rubbing problems. Figured I'd fix it before and not have to worry about it later. Not that it will always work, but at least I don't have to try it later if I have a problem.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
