o2 sims and extensions
Old Nov 24, 2003 | 12:29 PM
AZ2NV's Avatar
Question o2 sims and extensions
I plan on running hooker longtubes on my 99 Z28 A4 and I was wondering if I needed o2 extensions for both the passenger side and the drivers side? Will the SES light come on if I choose to use these? I haven't done anything internally to the engine. Also, where is the cheapest place to purchase both the extensions and the sims from? Thanks for your help with this matter.
Old Nov 24, 2003 | 01:06 PM
tekker's Avatar
i know u need them on the passenger side.. not sure bout the driver side.
/tek.
Old Nov 24, 2003 | 09:32 PM
99BlackZ28T56's Avatar
I don't know what extensions you'll need. You could always make your own. Just get the connecters from a parts store. Just make sure you use heat shrink to keep moisture out. I wouldn't cut the harness on my car.
I have a pair of O2 simms off my '99 for $55 to your door. I got tuning and had the codes deleted so I don't need them anymore.
Old Nov 24, 2003 | 11:02 PM
HtownZ's Avatar
you ll need both extensions, at summit $21.95 each, you can get 02 sims anywhere including summit if $88.95. no, the extensions will not trigger a code.
Victor Lamb
Aug 26, 2017 02:52 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
grabbem88
Apr 16, 2015 06:57 PM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
bee20e
Parts Wanted
Nov 27, 2014 05:20 PM
