misfire on 5 and 6 and the same time?
Old Oct 1, 2003 | 09:35 PM
chpmnsws6's Avatar
Unhappy misfire on 5 and 6 and the same time?
we auto tapped it and it showed over 1900 misses (both 5 ad 6 had 1900+ each) and all of em were today. it was running fine and so i went out to run errends in it and on the way home i took it to 2800rpm and then let off..... after that this all started happening. we changed 5 and 6 injectors to see if that was it but it wasn't the problem i guess since its still doing it. any thoughts?
Old Oct 2, 2003 | 09:45 AM
Black Sunshine/ 00SS's Avatar
I was getting the same thing. It started with #5, them spread to all the others on the drivers side. It seems to have been the connector pin on the coil packs. I got new pack & it is cool now. It appears that water got in there, and coroded the pins. I'll have to get something from Radio Shack to clean them off.
Switch the coil packs from one side to another, do an ATAP & see if the problem follows to the other side. Good luck.
Old Oct 2, 2003 | 04:25 PM
chpmnsws6's Avatar
thank you! i changed the pack to a spare one and it worked!
AdsoYo
May 2, 2018 03:21 AM
Klypto
Mar 23, 2016 09:05 AM
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
