Miles on your LS1's....
Old Jul 22, 2003 | 08:52 AM
  #46
chuck's Avatar
My '01 T/A rolled 30K over the weekend. I have a beater now, so the miles won't rack up so quickly.
The T/A has been abused, and has worn out 20 sticky tires so far (and nearly another set), and so far has been 100% reliable.
Old Jul 22, 2003 | 09:52 AM
  #47
DohHunter's Avatar
About 3800.
Old Jul 22, 2003 | 12:11 PM
  #48
350 HRSS's Avatar
The 99 TA has 38k on it!
Old Jul 22, 2003 | 12:59 PM
  #49
SpecForceZ28's Avatar
18k on my 02, I like to drive my cars
Old Jul 22, 2003 | 01:59 PM
  #50
TerrorDome's Avatar
41,600 on my '98z28
now i gotta run and catch the bus...see you folks in a bit!
(i'm not kidding)
Old Jul 22, 2003 | 02:11 PM
  #51
Keiii's Avatar
I have a 98 with 65,000 and
I have yet to notice oil burning or
oil consumption. It may be less
than a half a quart low if that after
3000 miles. Also engine runs fine with
no smoking at all.
Old Jul 22, 2003 | 03:31 PM
  #52
GoFast908Z's Avatar
Member
79,383 miles.......
-1 to 1 1/2 quarts every 5,000 oil change.
-3rd owner, about to hit tranny number 3. averaging 1 tranny per owner
-replaced squeaky serpentine belt 7 times, leaky water pump twice
-2nd owner bent the rear axle
-replaced driver side window motor 2 times, needs it again. replaced pass side window motor 1 time, needs it again.
-AC doesn't work 70,000
-clutch pack going out - right now
-3 broken tranny mounts
-battery cracked and leaked acid all over power wires ($200 to replace) - 70,000 miles
-2 broken wheel studs, last week
-a whopping 14 mpg city 19 hwy
-replaced u-joints at 75,000
-leaky differential at 75,000
-3 of the 4 emergency jack points bent out of shape.
All that, and I still love this car. Hoping this is the end of a string of problems - but even if it isn't I still will keep it.
Old Jul 23, 2003 | 05:52 AM
  #53
z28chrizz's Avatar
24500 and no oil drinking here. First time I put synthetic in it flashed the low oil light at about 2500 miles. Now when I change the oil I put in 6.5 quarts ( I also use the larger Mobil 1 filter ) ... seems to have no consequence (ie oil pressure doesnt drop over time due to the crank aerating it). I do this because during autocross events more of the oil stays up in the lifter valley and heads... gotta make sure I never starve the pump!
Old Jul 23, 2003 | 12:06 PM
  #54
XKnightRider's Avatar
Just turned 8k, the change oil light finally came on. I have changed my oil 4 times already! No oil consumption issues yet.
The only thing is I get sh!ty gas milage, must be the heavy foot.
Old Jul 23, 2003 | 12:48 PM
  #55
BlueEyesBlackZ's Avatar
1998 Z28 - 110,000 and it looks and runs like new! Just got cut outs, cross drilled slotted rotors, stall shift converter, whisper ram air.
Old Jul 23, 2003 | 03:32 PM
  #56
mook99TA's Avatar
46000 and no problems but a window motor and u-joints nothing in the oil or engine dept.
Old Jul 23, 2003 | 03:51 PM
  #57
FirehawkNS's Avatar
99 z28 w/ 41,000 miles on it and going strong.
Only motor related problems so far have been a leakey water pump!!! Replaced under warrenty, next time is my problem.
No oil consumption with 10w30 mobil one!!!!
Old Jul 23, 2003 | 03:54 PM
  #58
IrocManiac's Avatar
Originally posted by GoFast908Z
79,383 miles.......
Do you beat on it all the time? thats the longest list of problems I've read in a while on one of these cars...and whats up with that mileage?
Old Jul 24, 2003 | 12:56 AM
  #59
GoFast908Z's Avatar
Member
actually, I don't beat on it. It was the previous owners that beat the **** out of it. The last owner was reving to 5k in N then dropping it to 2nd to do burnouts - thus new transmission after it failed the same week I got it. I don't know what's up with my gas mileage. I even switched cars with my mom for a week, to see if she could get better mileage out of it. No such luck. She does like to drink a lot (the car that is. )
Old Jul 24, 2003 | 10:11 AM
  #60
antta99's Avatar
I have 67,000 miles with hundreds of drag passes on it. My car uses 1 1/2 to 2 qts depending on how much I race every 3k.It always has so its constant.
