Miles on your LS1's....
Old Jul 17, 2003 | 02:15 PM
  #16
dis3as3d's Avatar
hit 28k a week ago
Old Jul 17, 2003 | 02:22 PM
  #17
darrens99formul's Avatar
51,150 miles and counting. No oil consuption that I am aware of and so far nothing has gone wrong although I got the car used with 48,000 miles on it so who knows what work the previous owner had done.
Old Jul 17, 2003 | 02:24 PM
  #18
NEWBIE T/A's Avatar
Talking 49,500 here !
Been using about 1/2 quart per 3K since I bought it 2 years ago w/ almost 24K on the clock.
I attribute some of that to the 2800 stall converter - it revs more than a standard A4 would.
Minor glitches so far - rotors warped, t-top rattles, idler pulleys gone bad, trip meter on the instrument panel resetting in cold weather, POS O.E.M. battery leaked thru the positive terminal , and low coolant sensors ( on the 3rd, an it acts up if the temp outside is less than 70° ).
All minor stuff.
I did buy an extended waranty (aftermarket) just in case, though.
Britt
Old Jul 17, 2003 | 03:25 PM
  #19
Carrotop79's Avatar
46K and have just found oil coming from around the tranny to engine connection point. But was advised to check the intake manifold.
Old Jul 17, 2003 | 04:02 PM
  #20
myricekiller's Avatar
51,400 and runnin great. On a healthy diet of rice
Old Jul 17, 2003 | 04:46 PM
  #21
drasgear's Avatar
22K and it burns just over 1 qt every 3,000 (and I baby the thing). Best part is, GM Warranty says anything less than 1 qt per 2,000 miles is considered "acceptable" and won't fix it.
Old Jul 17, 2003 | 04:48 PM
  #22
IrocManiac's Avatar
Yeah see, I read an article that said they were designed that way for a reason but it coulda been GM propganda...I was like you designed it to consume oil
Old Jul 17, 2003 | 05:46 PM
  #23
S. Holley's Avatar
I have a 2000 SLP SS loaded w/ 52k now, ordered it and have been driving the hell out of it....
Been a very good car....
I had 02 sensor replaced 28K...(NOS diet only ran about 3 bottles through it)
BLown my front speakers (45K)
Need my rotors turned...(since 35K)
Already need my 3rd set of tires. (2nd set at 27K)
Pilot Bearing came apart in my clutch 38K....REALLY i was not beating on it?!?!?
Had a split in a interior panel (warranty)
Uses about .5 to 1 quart of oil between changes..(only mobil 1 here)
One battery....35K
Just had my rear end serviced (auburn unit..SLP option)
ANd my transmission....all MOBIL 1 syn.
Nothing else really....
LOVE IT WOULD NOT GIVE IT UP>>>> just wish I could drive better.....
Old Jul 17, 2003 | 05:58 PM
  #24
DS01Z28's Avatar
Thumbs up
coming up on 30K miles; no noticeable oil consumption.
Daryl
'01 Z28
Old Jul 17, 2003 | 06:15 PM
  #25
silversupersport's Avatar
30000 kms or 18000 miles and it burns about a litre or oil very 5000kms or almost a quart every 3000 miles. otherwise no problems yet.
Old Jul 17, 2003 | 08:09 PM
  #26
Jon98's Avatar
my '98 t/a just turned 16,000mi garage kept almost every day of its life, almost brand new condition.
Old Jul 17, 2003 | 10:03 PM
  #27
SSBIRDMAN's Avatar
Originally posted by camaro322hp
65K miles. ever since new, it's been using 1/2 to 1 quart per 3,000 miles. that was with 5w30. next change, i'm switching to 10w30 to see if that helps.
I tried the 10w30 but it did not make a difference. Mobil synthetic. My engine will consume oil the closer to the oil needing to be changed. Just turned over 90000kms.
Old Jul 17, 2003 | 10:59 PM
  #28
RS Dragster's Avatar
32k. Purchased it with 28K, so I only put 3K on in a year. Should be even less as time goes on. I'm in D.C. and my car's in South Dakota Damn insurance
As far as the condition, no probs except the usual window motors going bye-bye. Oh well, it happens....
Old Jul 17, 2003 | 11:53 PM
  #29
BlueLS1Z28's Avatar
34000 and still good to go
Old Jul 18, 2003 | 07:34 AM
  #30
amood's Avatar
82000----I have a couple of interior trim issues because a lot of the plastic parts are so small and frail. Also have a rhythmic "rub" sound in the rear....no change with new tires. Eventually Ill address the issue. Other than that----engine is impecable.
