LS7 in an f-body
Old Aug 14, 2006 | 07:21 PM
SpeedDemon02SS's Avatar
LS7 in an f-body
I was talking to a buddy last night over some beers...and the subject of ls7's came up. I was just curious to see if anyone has put one in an F-body? and how difficult it would be. noted, it would be alot more cost effective to build up the ls1, but i was just curious.
Old Aug 14, 2006 | 08:18 PM
IXLR894Z28's Avatar
Re: LS7 in an f-body
I don't know how hard the swap would be, but the engine alone costs almost $13,000. With that kind of investment you could build an LS1 to well over the 505 HP the LS7 is rated at. Just my .02. Sorry, just read the last sentence.
Old Aug 14, 2006 | 08:23 PM
myslowcamaro's Avatar
i havent done it myself, but read some refitting is necessary if you want the dry sump system. 427's have been used in 4th gens for a while now by lingenfelter and or calloway.
Old Aug 14, 2006 | 08:28 PM
lowered 93z's Avatar
there is a company here in michigan called kaytech and they have one in a 02 ss and it seems to run good but it would be much more effecient to build a ls1 But yes you can put a ls7 into a f body and i have no idea of the mods needed to make it fit
Old Aug 14, 2006 | 08:40 PM
oh, i am well aware of the costs. and i would never do it. as i said in my original post, you could build an ls1 up for much cheaper than 13k. i was just curious if anyone had done this.
Old Aug 15, 2006 | 03:27 PM
Capn Pete's Avatar
The physical size of the block is the same, so as far as "fitting" into the car, there's no issue (it's no different than a 267 - 400 SBC). The only thing you'd have to "work" on would be fitting the dry-sump system of the LS7.
...now if GM would allow running THEIR 427 LS7, bought through GMPP (instead of an aftermarket 427) and they maintained your factory warranty with it, THAT would be a sweet deal. Now I realize that most/all warranties are probably up on the late 4th-gens, but on the upcoming 5th-gen, that would be cool (if they don't already offer a ~500HP option?).
Old Aug 15, 2006 | 03:37 PM
Bayer-Z28's Avatar
A guy on LS1tech did it... W/ N2O... LIke 500hp wasn't enough!
http://www.ls1tech.com/forums/showthread.php?t=547405
Check the LS2/7 room at LS1tech.com
I'm actually concidering the Devil Ray punched + stroked 427 LS2... A small bit cheaper. Just have to find an LSX cable TB for the LS2.
im thinking of an ls2 powered z28, and maybe an ls7 powered SS? id be in line for one.
Old Aug 15, 2006 | 03:39 PM
Bayer-Z28's Avatar
LS7 and the 427 LS2 arre about the same thing. Maybe some block differances. If I were to go w/ the TRUE ls7 I'd do the Warlock Block.
Old Aug 15, 2006 | 03:41 PM
then why is the ls2 vette rated at 400hp and the ls7 505hp?
Old Aug 15, 2006 | 03:59 PM
Bayer-Z28's Avatar
LS2 is 364ci or something close to that... the LS7 is a 427ci, like that from the factory..
The Devil Ray 427 motor is a LS2, just revamped. I believe they also sell the long block.
http://www.motorsporttech.com/print/...rochure01.html
Old Aug 15, 2006 | 04:08 PM
thats what i thought. i was just talking about factory engines.
Old Aug 15, 2006 | 04:18 PM
do you mean the warhawk 454?
Old Aug 15, 2006 | 04:23 PM
JakeRobb's Avatar
Super Moderator
Yeah, but if you supercharge an LS1...
Unless you're swapping in a big block (and even then I'd have my doubts), there is very little reason not to upgrade the factory LS1. The potential is phenomenal.
Old Aug 15, 2006 | 04:59 PM
Bayer-Z28's Avatar
I understand and agree that these LS* engines are good. But stock displacement can only take you so far. Unless you have GOBBS of $$$.
I kinda see it this way. You'll ahev to build a stock LS1 to 500hp. The LS7 makes it stock, if you strap on soem forged internals and throw 25lbs of boost at it, you'll have a MONSTER!
And yes, I might have been thinking about the 454 Warhawk, I remember reading about it in GMHTP.
