LS6 intake or Lingenfelter?
Old Apr 23, 2003 | 06:39 PM
longgunn's Avatar
Which is better, the LS6 intake or the Lingenfelter? Either way I can get them both ported for free through a friend. Is one better than the other?
Old Apr 23, 2003 | 06:51 PM
Blkknight's Avatar
Well you really can't port a composite intake too well. As for the Lingenfelter :cough:Holley:cough: intake it will only prove beneficial if you are running big power and get it port matched. Otherwise its been proven to perform the same as the LS6 intake. Except in the area of heatsoak where it fails over the LS6. Most of the big guys are just using the stock LS6.
Old Apr 23, 2003 | 06:52 PM
kringer2's Avatar
i don't know which is better but i'll take the other one. if i were you though i would probibly take the lingenfelter.
Old Apr 23, 2003 | 07:22 PM
SSCamaro99_3's Avatar
Can I have the LS6 intake, PPPLLLLLEEEAAASSEEEE!!!!!!!!!!!!
Old Apr 23, 2003 | 08:43 PM
longgunn's Avatar
haha, sorry, I don't have either of them yet, should have said I can get the one I buy ported.
How much for an LS6 intake if anyone knows?
Old Apr 24, 2003 | 08:27 AM
bbentley40's Avatar
I think PACE sells them for 395. I went with the Lingenfelter intake because eventually I am going to do heads and I will have them port matched. I am going to reach 400 rwhp NA one way or another!
Old Apr 24, 2003 | 04:17 PM
96fbirdA4's Avatar
The lingenfelter intake will suffer from heat soak, which will make it almost mandatory that you take a bag of ice with you to the track in order to run your best times.
Since the LS6 intake is plastic, you won't have this problem.
Get the LS6 intake.
Old Apr 24, 2003 | 11:57 PM
tainted's Avatar
What does this mean? :\
can you please explain why you would need that stuff to match?
Look at my sig, you'll understand why i'm asking this question. Thanks boys!
Old Apr 25, 2003 | 12:10 AM
stik6shift98's Avatar
ported to match flow...maybe
longgun i would get ls6 intake
Old Apr 25, 2003 | 12:06 PM
maddboost's Avatar
Well Id go with the ceramic LS6 unless you plan on running like 15 psi of boost in which case the ceramic intake would fly apart. As far as porting the ceramic LS6 everyone I heard who did that either saw no performance gain or a drop in performance, the LS6 is really one of the best intake manifolds ever made. So in conclusion lots of boost go with Lingenfelter(Holley), low or no boost go with ceramic LS6.
Old Apr 25, 2003 | 01:45 PM
Ceramic I thought it was nylon/polymer.
Old Apr 25, 2003 | 04:03 PM
ChrisLS1Bird's Avatar
Thumbs up
no, it's made out of clay and fired in an oven. that's why you have to make sure to always close your hood gently..if you just slam it shut, the intake will shatter. what a mess.
they also have porcelain and fine china versions. I think tbyrne sells them. there's this one really pretty one with a portrait of a rising sun over a mountain lake fired in..it's beautifully detailed by hand, but I think it costs almost $5000. that's more of a collector's version that you don't install but just keep on the shelf.
lol
Old Apr 25, 2003 | 04:40 PM
lol
Old Apr 26, 2003 | 02:21 AM
Old Apr 26, 2003 | 01:18 PM
psychocabbage's Avatar
lol
Can we get an unfired version so can we just wet sand it to port it? Anyone have a kiln?
Does the glazed version provide more airflow since its smoother?
hmmm questions questions... :P hahah
HarleyZ28
Oct 5, 2015 06:23 AM
R@mpage
Apr 20, 2015 10:02 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
hotrodyou1
Dec 20, 2014 10:05 PM
