LS6 Intake
Old Sep 4, 2003 | 05:34 PM
zoomjrl's Avatar
LS6 Intake
what all is involved with changing the intake? What all do I have to take apart? Do I have to get anything aligned or tuned after the install?
Old Sep 4, 2003 | 05:49 PM
AFDAREDVL's Avatar
You have to take the fuel rails off, then the 8? i believe intake bolts and then get the vacumme lines from the back undone to take it of. Then cover the intake ports by the heads with rags or something so nothing gets into the head.
Then you have to get the coolant line that only goes from driver side head to passenger side head. with new gaskets. Because the Ls1 intake has a coolant line that looks like a big H under the intake, and if you try to put that back on with the ls6 it wont work.
good luck!
Old Sep 4, 2003 | 05:57 PM
zoomjrl's Avatar
thats what I figured, more trouble then its worth right now, saw a deal on ebay I couldn't pass up, but now the cost has gone up, so I won't be buying.
Old Sep 4, 2003 | 06:02 PM
AFDAREDVL's Avatar
Its not really that hard if you now how to turn a wrench.
But if the intake doesnt come with that line you gotta order it from a chevy dealership. its like 50 dollars and some change.
Old Sep 4, 2003 | 09:36 PM
danziger's Avatar
Piece of cake install. The only pain is the little tube attached in the back. Basically unbolt the TB, undo the fuel rails and pop them off with the injectors attached, undo the intake bolts and various hoses, install the coolant line shunts and install the intake in reverse. Easy job with average tool skills.
Old Sep 4, 2003 | 09:39 PM
rick99ws6's Avatar
www.ls1howto.com
there's a writeup of an LS6 intake install in there
Old Sep 5, 2003 | 12:13 PM
zoomjrl's Avatar
cool, thanks, i read fuel rails and turned my head
Old Sep 5, 2003 | 02:58 PM
02Camaroguy1775's Avatar
I've heard a few different times that the '01 and '02 Z comes with LS6 heads... does anyone know for sure if this is true or just a rumor?
Old Sep 5, 2003 | 08:09 PM
AL SS590 M6's Avatar
Moderator
Wrong.
Some have LS6 blocks but none have the heads.
Old Sep 5, 2003 | 10:08 PM
Lan01z's Avatar
hmm.. how would you be able to tell if you had an ls6 block?
Old Sep 6, 2003 | 12:07 AM
Moderator
Do a search. There was a big discussion not long ago.
Old Sep 8, 2003 | 01:23 PM
Constrictor98TA's Avatar
For what its worth, swapping intake is NOT hard. My first time I was pretty nervous too, but after taking it off and on, by the third time, I was able to get the intake off in less than 20 minutes, swapped the fuel rail and injectors in about 5 minutes, then had the new one back on in another 20 minutes....45 minute job. Just don't break your oil pressure sender!
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
R@mpage
Apr 20, 2015 10:02 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
birdblack
Dec 30, 2014 06:59 PM
hotrodyou1
Dec 20, 2014 10:05 PM
