LS1 Heads
Old Dec 3, 2007 | 03:34 PM
kyle67camaro's Avatar
LS1 Heads
Ok I am going to do heads and cam on my ls1 and I found some ones that I want, but the question I have is what is the bennifit of a bigger camber cc.
Old Dec 3, 2007 | 07:39 PM
Zitty'sZ's Avatar
You would benefit from a bigger chamber only if you are supercharging or going with a turbo charger. Bigger chamber equalls lower compression ratio. Normally aspirated engines benefit from smaller chambers which raises the compression ratio.
Old Dec 3, 2007 | 09:32 PM
Kraest's Avatar
Retired
You want to stay around a 58-62cc combustion chamber for an NA application on the stock bottom end.
If you have 93 octane available, I'd go with a 58-59cc head and Cometic .040". If you don't have 93, I'd go with around a 62cc head and an OEM head gasket.
Like it was said before:
The smaller the chamber, the higher the compression... and vice versa.
Old Dec 6, 2007 | 07:56 AM
teke184's Avatar
are you sure you're not seeing intake runner size and thinking chamber size?
rideordie
Nov 5, 2019 04:52 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
