how to replace bulb for turn signal?
Old Nov 26, 2003 | 06:40 AM
Buffdaddy's Avatar
I think my turn signal bulb is burned out. Because the arrow inside lights up, but is frozen solid green. However the day time running light still lights up. Is it a burned out bulb or fuse? Do I have to replace the bulb from the inside or does the turn signal pop out? Thanks for your help.
Old Nov 26, 2003 | 08:31 AM
rncotton's Avatar
If you're not blinking, but just staying on, then you have a lamp out either front or rear.
Rear lamps are replaced from the inside. Front lamps (on the T/A at least) are replaced from behind.
Old Nov 26, 2003 | 08:32 AM
abarus's Avatar
The turn signal bulb is burned out. To replace this the easiest way is to open the hood and take out the headlight. This only thing holding the headlight in is a 10mm bolt. Remove this and the headlight will come out and give you easy access to replace the turn signal.
Have a good Thanksgiving,
Old Nov 26, 2003 | 10:56 PM
99blackSS's Avatar
Exactly, except have a bad thanksgiving.
I always was against that way until it dawned on me how simple it is to take out the headlights. Otherwise its really hard to reach the turn signal.
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
formula79
26
Aug 5, 2002 12:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
