How long are the four battery cables?
Old Mar 13, 2007 | 10:59 AM
Need4Camaro's Avatar
I am going to have those cables replaced with 2 custom cut Gauge Wire, This won't hurt any electronics would it? Would I need to do the same to the negative cable? Also will sound wire be okay or will the insulation melt?
Old Mar 13, 2007 | 04:58 PM
Also there's a Black Cable that runs infront of the fan and down below into the block on the driverside, How is this connected as there feels to be a boot over it...
Edit: Found out this was the alternator, what sized bolt holds the cable to the alt?
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
97z28k&N
Jan 9, 2015 04:58 AM
Sarahrope64
Nov 27, 2014 11:17 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
