Help! The window motor I got from Autozone is different!
Old Dec 12, 2003 | 10:05 PM
Mike94ZLT1's Avatar
HEEEELLLP!!! I got my car door all torn apart, fun thing to do on a friday night, and I noticed that the door is completely different than the instructions that I have been trying to follow.
http://shbox.com/page/windowmotor.html
The window motor kinda looks like the right one, and I checked with autozone and they did get me the right part number. Now there are a few differnt holes already drilled by the rivets I could use, and 3 of the 4 line up perfectly with the holes in the motor. Should I (a.) Use the 3 holes that work and settle for that, (b.) drill a 4th hole or (c.) go to the dealer tomorrow and get raped paying for a new window motor that will be an exact match? Thanks guys!
Old Dec 12, 2003 | 10:57 PM
Schantin's Avatar
Re: Help! The window motor I got from Autozone is different!
Good gosh, man....avoid the dealer! You could probably feed a monkey a 12-pack of beer and set him loose on your Z with a wrench and achieve better results.
The directions you have are top notch. I replaced the window on my old 97Z with those a couple months ago and had no problems. The motor itself has SEVERAL holes drilled around it. Only THREE of those holes are used to attach the motor to the retaining bracket and mesh the motor gear with the window reluctor. (The reluctor's the big crecent moon shaped gear on the window).
Duble check the diagram in Shoebox's instructions against your door carefully. There should only be three holes to drill and they will expose the three rivetsthat hold the window motor to the door. If the existing holes already expose three rivits, then that's all of them. The rivets need to be drilled through. I used a 1/8"? bit for this.
Once the three rivets are found/ drilled out, the Autozone motor can be installed by sliding it behind the metal door bracing and into position. Use the three supplied nuts/ bolts that came with the Autozone motor to secure it. Then test the motor before screwing the door panel back into place.
Also, keep your reciept for the "lifetime warranty". I only got 16 months average life from my Autozone motors on my old Camaro!!
Schantin
2002 Camaro Z28 M6 (with manual windows because I got tired
of performing this fix every year!!)
Old Dec 12, 2003 | 11:14 PM
Mike94ZLT1's Avatar
Well, 3 of them line up. Heres the problem though... THERES 4 RIVETS!!! and theyre all exposed. I wish I had a digital camera.
Old Dec 12, 2003 | 11:22 PM
Aklaim's Avatar
Just attach the 3 that line up, dont worry about the one that doesnt line up.....it wont hurt anything.....
Old Dec 13, 2003 | 12:01 AM
Ferocity02's Avatar
The holes on the new motor will line up with the holes on the door..... Whats the problem?
Old Dec 13, 2003 | 12:34 AM
Mike94ZLT1's Avatar
me = retarded. I saw 4 rivets, got all excited thinking "hey mines different I dont have to drill!" and got lost from there. I think I got it. Thanks, I love you guys!
Old Dec 13, 2003 | 12:41 AM
Schantin's Avatar
Just to be sure you got it..... only THREE rivets/ screws need to be attached on the new window motor Seriously, on the LT1 cars only three rivets are used. That's what Shoebox's directionsa are for. There is no structural difference between the door/ window motor of a 96 Z28 LT1 and a 98+ LS1 model. Just drill out all the rivets on the existing motor, atach the new one with the THREE set nuts/ bolts...... and you're back in the power window business........ worry free.
Good luck.... it shouldn't take too long. I changed the motor in my old 97 Z28 in under 2 hours
Schantin
2002 Camaro Z28 M6
Manual everything....to prevent posts like these (no offense )
Old Dec 13, 2003 | 11:41 PM
psychocabbage's Avatar
hmmm, now should I be feeling good about not being able to roll down the passenger window?
(I dont have power windows...)
Old Dec 17, 2003 | 11:06 PM
99snkklr's Avatar
Make sure when you get the new motor installed to grease the hell out of the regulator. I bought a can of heavy duty white lithoum lubue grease and I sprayed the entire track where the roller rides when the window goes up/down. After you put the door panel back on, put the window all the way up and open the door. Look at the inner door(where the option code sticker is and where the door lock/latch is) at the base of the window there is a triangular piece of rubber. I used a brand new, sharp as hell, razor blade and trimmed the black rubber away from the glass, just a little, to make sure it wasn't touching. This peice of rubber acts as a seal of sorts, but it also creates A LOT of friction on the glass when it goes up/down. This added friction will eat up motors really quickly.
Old Dec 20, 2003 | 09:34 PM
Vortech355's Avatar
dam now you guys got me want to bypass the electric **** and get a manual window set up lol
Keenan
Jan 19, 2023 12:24 PM
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
