Fuel Pump dying?
Old Apr 10, 2005 | 04:51 PM
Meccadeth's Avatar
Fuel Pump dying?
Today when I got back home from a drive, I noticed a rather loud whining noise coming from the back of my car under the hatch. So I took it for a drive again to see if it kept doing it, and when I blipped the throttle sometimes it felt like the fuel was being cut off. When I got it back home it sounded even louder...any of you guys know what it could be?
Old Apr 10, 2005 | 07:22 PM
Meccadeth's Avatar
Re: Fuel Pump dying?
I just took it by my friends house and he said its definately the fuel pump thats dying...He wants to know if there is a trap door through the top of the gas tank that he easily access it through or if he has to pull the tank out completely??
Old Apr 10, 2005 | 07:24 PM
Blue89Bird's Avatar
there isn't one there, but you can put one in. Do a search, there is a good step by step guide of what to cut and how.
Old Apr 11, 2005 | 12:33 PM
Meccadeth's Avatar
Holy crap, I just called a shop for an estimate to replace the pump and fuel filter....$850!!! For a $100 part! Looks like a nice learning experience for me...
Old Apr 11, 2005 | 03:41 PM
psychocabbage's Avatar
upgrade! may as well go for some flow in case you mod hard later!
Old Apr 11, 2005 | 10:30 PM
blackraven's Avatar
I have an LT1 car and just replaced the fuel pump last summer. It took my buddy and I a good weekend to get it done. The GM fuel pump is $400 from a dealer so you might as well get an aftermarket pump that has more flow and costs a lot less. The hardest part about the whole job is getting the tank out from its home. The problem is (at least on my 96) the filler neck it one long piece attached to the tank...there is no rubber to help the tube flex. Good luck with the project
Old Apr 11, 2005 | 10:54 PM
Blue89Bird's Avatar
which is why you install a access panel so next time it goes out it takes 30 mins to replace.
Old Apr 11, 2005 | 11:25 PM
raroz28's Avatar
I put in a walbro pump, 130. Not that crazy about it. It takes a while to start the car if I don't prime it a few times with the key. I have a little loss of power, I think it's fuel pump related. It just started doing this, and the pump has no warranty... 60 days I think, but that's over..
The whining... Sounds like the filter is getting clogged somehow. That's what would make it whine. Definitely do the trap door. If you cut a trap door you're looking at a 1 hour job. Tops. Even for a first timer. It's so easy once you have access to everything on top of the tank.
Old Apr 12, 2005 | 10:33 AM
sir dyno's Avatar
Others say removing the gas tank is not that difficult just time consuming. Also that you would need to clean the tank so that would mean taking the tank out. Cleaning the tank meaing just add gasoline and pour it out of the tank, to take out any debris in the tank.
Thanks for the walbro pump 130 info, loseing horsepower is something that is not got for the camaro.
Old Apr 12, 2005 | 02:39 PM
raroz28's Avatar
Cleaning is not necessary, IMO. Wouldn't hurt though. I meant walbro pump, and it cost me $130. It's a high flow 255 LPH pump. Nice specs, but they have a tendency to prove to be lemons after a while. I'm not the only one to get a weak pump from them.
Dropping the tank isn't all that hard. If it's empty it'll be easier. Just depends on how much time you want to spend. Removing the rear end... Exhaust maybe? Not sure about that. Tools, time, and a garage to do it in. That's all it takes. Either way is fine. I am happy I did the trap door, or I'd probably be pulling that tank again to replace this dud Walbro sold me.
grabbem88
Mar 18, 2015 01:25 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
