Fra
Old Dec 24, 2002 | 08:25 PM
  #16
96SFLZ's Avatar
Originally posted by stik6shift98
im sayin u have to do that cutting when u get whisper ram air or fast toys ram air......
Dude, you were talking about a lid, now you talking about a ram air setup. Two different things
With a lid...no, you do not have to cut anything.
With the FTRA or the like...yes, you do have to cut.
Old Dec 24, 2002 | 08:29 PM
  #17
stik6shift98's Avatar
grrrrrrrrrrrrrr
im sayin with the lid that gets rid of baffles so i cant do that mod
and with whisper ram air i had to cut bottom of airbox....
get it?????
Old Dec 24, 2002 | 08:38 PM
  #18
Flat_Tire_'s Avatar
Ohhhhhh ya, in that case you do, I'm just talking whisper lid and FRA.
Old Dec 24, 2002 | 08:44 PM
  #19
96SFLZ's Avatar
grrrrrrrrrrrrrr
Never heard of a !baffles mod but you don't have to worry about them anyway.
get it?????
Correct!
Old Dec 24, 2002 | 08:45 PM
  #20
lol
glad we got that straitened out
Old Dec 29, 2002 | 10:41 PM
  #21
BlazeOne's Avatar
!FRA is all I got at the moment and heres the results.
1/8 mile 8.641 @ 84.96mph
60' - 2.001
Dynamometer
312.2 at 5240rpm
328.8 at 4400rpm <----notice torque peak went up 400 rpm
Old Dec 29, 2002 | 11:44 PM
  #22
99blackSS's Avatar
Being the hardcore guy I am I did the FRA on my V6 Camaro and it wasn't worth the troubles on that car. The little gain wasn't worth the pine needles the filter collected.
I could see it being a worthy mod on a LS1 though.
Old Dec 30, 2002 | 05:11 AM
  #23
2002Z28SSConv's Avatar
If you commonly drive on back roads or where there is tall grass being hit by the plastic spoiler under the car, crap will get blown up into the filter area. Leaves, grass, pine needles, bugs and small sticks can blow up into the filter cavity and even get lodged at the top of the radiator AC condensor area. If you use a K&N they tend not to seal real good. I get little bits of grass every now and then stuck on the front of my MAF screen. I check the filter and surrounding areas about once a month. You just have to remember to check everything periodically.
Old Dec 30, 2002 | 12:57 PM
  #24
dmaastr's Avatar
I use my 98Z28 as a daily driver and sometimes at work it can get pretty dusty. So, I made a block off out of thin sheet aluminum that slides under the air box and below the filter. I keep in in place with 2 small screws. If I know I'm going crusin with the Z, I can easily unscrew it, slide out the sheet, re-attach the lid and I'm back in business. Takes about 5 minutes.
I think this mod is one of the best FREE mods you can do. Noticable difference.
My84Z
Jul 26, 2003 08:08 PM
darrens99formul
Jun 27, 2003 11:52 AM
JimMueller
Nov 20, 2002 08:10 AM
whitelightnin
Aug 2, 2002 11:53 AM
whitelightnin
East South Central
29
Aug 1, 2002 10:40 AM
