coated headers
Old May 21, 2003 | 10:04 PM
in2ta's Avatar
coated headers
I purchased a set of SLP long tube headers and had them installed in September, since then I have put about 7,000 miles on them. I have noticed discoloration on them. I t started on one tube after the flange at first and is becoming dark brown. The rest are starting to show slight discoloration. Is this normal or is this the sign of a problem?
Old May 21, 2003 | 10:25 PM
sumo21bob's Avatar
If they are not coated(which i am assuing they are not) then the discolleration is normal. it is just do from the high temperatures of the exhaust gas that passes through them. if this does bother you one possible solution is to have them jet-hot coated but that would require removing them and having them sent away.
Old May 21, 2003 | 10:33 PM
in2ta's Avatar
Well what bothers me is the fact that they are coated, they are the slp tuned lenth long tubes coated in and out
Old May 22, 2003 | 07:34 AM
SS HOTTIE
Guest
Posts: n/a
What coating? I have jethot and they are discoloring as well.
Old May 22, 2003 | 10:12 PM
in2ta's Avatar
well as long as it is normal I was just thinking maybe i was burnin them up by running lean or something but I smell rich so I guess it is normal
Midnight_Z
Feb 16, 2016 09:36 PM
HarleyZ28
Oct 5, 2015 06:23 AM
R@mpage
Apr 20, 2015 10:02 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
