Clear corner light installation.
Old Jul 28, 2002 | 06:54 PM
ExMustangOwner's Avatar
Question Clear corner light installation.
Which bolts do I take off to get the head lights out of the way? I took one off and it was moving around but I couldnt' find the other bolt. Any help would be mcuh appreciated.
J.J. (Nashville, TN)
2001 Camaro Z28 M6
Old Jul 28, 2002 | 08:58 PM
silver96z28's Avatar
Post
Remove the bolt and bracket from the light and radiator support, this is the only bolt that holds it. There is a bolt that fits in a slot behind the low beam, just slips out, it takes some careful fanagaling to pull it out.On the turn signal make sure you take out all 3 bolts that hold it.Hope this helps.
Kurt, Sebring Silver mn6 2002 Z28,17"ZR-1 wheels,hurst billet shifterw/ Lou's short stick, clear corners, more to come, as does the cash
97FormulaWS-6
Sep 11, 2002 11:57 AM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Aug 22, 2002 11:53 PM
97FormulaWS-6
Aug 5, 2002 05:15 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
