Clear corner light installation.
Which bolts do I take off to get the head lights out of the way? I took one off and it was moving around but I couldnt' find the other bolt. Any help would be mcuh appreciated.
J.J. (Nashville, TN)
2001 Camaro Z28 M6
2001 Camaro Z28 M6
Remove the bolt and bracket from the light and radiator support, this is the only bolt that holds it. There is a bolt that fits in a slot behind the low beam, just slips out, it takes some careful fanagaling to pull it out.On the turn signal make sure you take out all 3 bolts that hold it.Hope this helps.
Kurt, Sebring Silver mn6 2002 Z28,17"ZR-1 wheels,hurst billet shifterw/ Lou's short stick, clear corners, more to come, as does the cash
