Changing plugs
Old May 6, 2005 | 04:13 PM
cop_camaro's Avatar
Changing plugs
I had the plugs changed in my 97 LT-1 at 101k miles, and was a B*^#h to do!!
Are the LS-1 engines any easier to do?
I have 108k on the original ones in my 2000, runs good but think I should give the ole girl a fresh set.
Suggestions??
Old May 6, 2005 | 04:38 PM
2001NBMZ28's Avatar
Re: Changing plugs
Driver's side is easy, remove the air tube on passenger side. #8 was the PITA for me, but got it from the top. I think there's a writeup at installuniversity.com
Old May 6, 2005 | 05:25 PM
myslowcamaro's Avatar
Re: Changing plugs
no problem at all for me.........i had the engine dropped.
Old May 6, 2005 | 11:19 PM
angel71rs's Avatar
Re: Changing plugs
Clearance was much better than my 89 Formula 350 once I popped off the air tubes and coil packs on passenger side.... except for #8.
Mine were incredibly tight, but others have said theirs weren't.
edit: Holy jeez, 108K!!! Did mine at 50k and they were crap, bet you feel a good difference, I know I did.
Old May 7, 2005 | 04:25 AM
CtRw's Avatar
Re: Changing plugs
all are easy to do with ur plug socket and just a 3/8 in ratchet. #8 will sometimes need to be done from the bottom but either way its a PITA!
Old May 7, 2005 | 07:40 AM
DanBUCF's Avatar
Re: Changing plugs
Throw a set of long tubes on there while you're doing it and it makes the job that much easier.
Old May 7, 2005 | 02:16 PM
fredmr39's Avatar
Re: Changing plugs
That's what I waited for
PCLZ28
Dec 24, 2015 05:19 PM
captcorvette
Mar 7, 2015 12:37 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
