cam size
Old May 6, 2004 | 11:58 PM
  #16
Lt1 and Ls1's Avatar
We have some very knowledgeable people on this board
Old May 7, 2004 | 02:12 AM
  #17
mullettour's Avatar
Originally posted by LWM
LS-1 F-body cams
98-00: 202/210 .496/.496 116 LSA
01-02: 198/197 .478/.478 115 LSA.
LS-6 cam
204/218 .551/.547 117.5LSA
LWM
I don't know where you got your info, but I found these specs on LS1tech's website.
these are the actual stock ls1 cam specs on the fbody as spec'd by comps
stock 98 trans am cam
duration@.050 198.86 intake 209.25 exhaust
lift .498 intake .497 exhaust
LSA 119.45
stock 02 trans am cam
duration@.050 196.37 intake 208.72 exhaust
lift .464 intake .479 exhaust
LSA 115.92
I've also seen these specs in books and on other websites.
Old May 7, 2004 | 03:13 AM
  #18
AL SS590 M6's Avatar
Moderator
Originally posted by mullettour
I don't know where you got your info, but I found these specs on LS1tech's website. I've also seen these specs in books and on other websites.
But the specs he's using are the advertised specs. Which are the general target specs for the production cam.
The ones you're quoting are actuall measured specs of 1 cam. Well we all know that there is a range of acceptable sizes from the factory. That's why there are differences in how the cars run. Some are extra hot, most are average, and some are extra slow.
Old May 7, 2004 | 09:20 AM
  #19
LWM's Avatar
LWM
I got those # from this board.
http://web.camaross.com/forums/showt...hlight=ls1+cam
And from the LS1.com board
http://www.ls1.com/forums/showthread...=ls1+cam+specs
this thread shows the Corvette LS1 cam to be near what you have indicated.
These numbers from LS1.com also
Stock cam information for the different years:
C5's
1997-00 LS1 C5 202/210; .472/.479; LSA: 117 Base circle: 19.7mm
2001-02 LS1 C5 198/208 ; .500/.500; LSA:115.5 Base circle: 19.7mm
2001 LS6 C5 Cam: 204/211; .525/.525 ;CL:118/114; LSA:116.0; Base Circle: 19.3mm (-0.0158")
2002 LS6 C5 Cam: 204/218; .551/.547; CL:120/115; LSA:117.5; Base Circle: 19.0mm (-0.0276")
Chevy Hot Cam 218/227; .525/.525; LSA: 112
F-bodies
98-00s had a 202/210 Dur @ .050, .496/.496 lift , 116 LSA or pretty close to those specs.
01-02s had a 198/197 Dur @ .050, .478/.478 lift, 115 LSA.
All pretty consistent with what I originally posted.
The joys of "search".
Hope this helps
LWM
Old May 7, 2004 | 11:14 AM
  #20
Capn Pete's Avatar
I don't know if this is an accurate source or not, but I was just looking at SLP's page for 1.85:1 roller rockers, and they list the various cam lifts after installing the 1.85's, so I did the math to go back to stock:
'98 - '00:
.544" X 1.7 / 1.85 = .49989" (<-- round it to .500"? )
'01 - '02:
.521" X 1.7 / 1.85 = .47876" (<-- call it .479")
But who knows if they're being 100% specific about that, or if they're estimating/generalizing!?
Old May 7, 2004 | 04:17 PM
  #21
mullettour's Avatar
C5's
F-bodies
01-02s had a 198/197 Dur @ .050, .478/.478 lift, 115 LSA.[/B]
As far as I know 97-00 C5 and 98-00 F-body had the same cam specs as well as the 01-02 C5's and F-body's.
Oh yeah, those cam specs I listed were ones from a guy who sent those stock cams in to comp cams and had them measured so I'm pretty sure they are accurate.
Old May 13, 2004 | 01:27 PM
  #22
SLPZ28's Avatar
I went with a Comp 224/228 with a 581/589 lift 112 LSA I had to have a lot of PCM tunning. On the other hand my friend went with a bigger cam(more duration) and a 114 LSA and no tunning and his car drives fine I made about 45-48RWHP and40RWTQ from the cam. If I do it again I will go with a 114LSA!
Old May 14, 2004 | 04:53 PM
  #23
D James's Avatar
whats the biggest cam that will pass California emissions? I imagine nothing to big Just wondering
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
1775.Z28
Jan 11, 2015 10:51 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
