Cam and rocker arm?
Old May 1, 2006 | 03:54 PM
  #31
mrr23's Avatar
Re: Cam and rocker arm?
not everyone wants a cam. or a cam that big for their everyday driver.
Old May 1, 2006 | 04:39 PM
  #32
Greed4Speed's Avatar
But if your running longer rockers you're creating the same effect and stresses as a little larger cam so whats the diff?
Old May 1, 2006 | 04:42 PM
  #33
mrr23's Avatar
idle, driveability, emissions passing, sound (some want stock sound), not having to tune. there's five.
Old May 2, 2006 | 01:18 PM
  #34
Again, you can do the same with a cam.
The CheaTR come to mind.
Old May 4, 2006 | 06:36 PM
  #35
mrr23's Avatar
just repeating myself.
Old May 4, 2006 | 09:50 PM
  #36
And thats fine if they want to spend more money for less power.
The fact is, rockers will do nothing a cam can't.
Even all 5 of your reasons for getting not getting a cam. The LPE GT2-3 fills all those requirements plus will give you more power than rockers.
And as I said, having to change springs makes the "simple bolt on" concept null and void since most simple bolt on type mechanics aren't going to have the tools.
Now if they were priced like earlier engine rockers, then yes they would be worth the $.
Old May 5, 2006 | 12:02 AM
  #37
mrr23's Avatar
again, i agree with you. a cam is the way to go cost/hp wise. but, for those that do not want to do a cam, it is a viable alternative. to say they are a waste would be an incorrect statement. because you do gain power. so, it's not a waste. if your only thought is cost, then it might be. depends on the customer.
Sauced
Apr 12, 2015 10:18 AM
carl.froehlich
Mar 13, 2015 12:38 AM
1775.Z28
Jan 11, 2015 10:51 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
