blinker prob. kinda long
Old May 28, 2003 | 05:06 AM
Lee95T/A's Avatar
on my g/fs 99 z28 her blinkers wont work...bulbs are good fuses are good ...hazards work...no light comes on inside ...no clickin noise either ...also the criuse control doesnt work either they went out around the same time im not sure if exactly the same time if that matters ...whats the deal does anyone know ?? any suggestions would be appreciated
Old May 28, 2003 | 11:59 AM
redlt1z28's Avatar
Well you can try the flasher. They are real cheap and that might be your problem. You can get it from any local auto parts store. It plugs in somewhere under the dash, you will see it. Hope this helps.
Old May 28, 2003 | 01:21 PM
95GRNZ's Avatar
Thumbs up
Duh!!! Very obvious!!! Go get some more blinker fluid!!!
Now that we got that out of the way... Since there is no clicking sound, it probably is the flasher.
TS
parkers Z28
Mar 11, 2016 08:14 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
snksknr94
Aug 2, 2002 07:31 PM
