Best Cam For An LS1 Engine???
I was wondering with a healthy moderate to big cam for every 50 horsepower usually ignition timing needs to get turned down around 2 degree's for every 50 Horsepower added, unless this does not apply to the LS1's.If running a 150 shot that would be 6 degree's off of timing.I was wondering would this create a problem with the Idling?? I had a similar problem in 2 prior car's with backing off the timing 6 degree's. I'd probably pick something close to a F13 cam.
The timing issue you refer to is usually not for big cams, but for nitrous use. Maybe on some platforms you may want to pull back some timing for an aggressive cam, but thats because most of those platforms have horrible combustion chambers that need a TON of timing (low 40s in some cases) to make power. LS1s on the other hand make their power with only 26-28 degrees.
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Nov 23, 2014 10:33 AM
