99 LS1 Z28 with high idle speed
Old Sep 16, 2007 | 06:25 AM
UK_chevyV8's Avatar
Question 99 LS1 Z28 with high idle speed
Please help, any advice would be greatly appreciated, could it be a dirty MAF sensor or time to change the spark plugs / ignition leads?
Over the past few weeks the idle speed has gone from around 600/700 rpm to just under 1000rpm.
When I stop and the engine idles, it often goes down to around 600/700 rpm, tick over is almost smooth, but then the idle speed slowly increases until tick over is perfectly smooth.
If I hold it on the brake and put it into drive then the engine is loaded and the revs go down to 600 and it runs perfectly smooth.
Normal driving and performance is fine.
rideordie
Nov 5, 2019 04:52 PM
Deadbolt24
Dec 18, 2014 08:18 PM
siguy
Nov 27, 2014 10:07 AM
IRABuss
Sep 7, 2011 09:08 PM
Jul 4, 2005 05:00 PM
