cams....
Old Sep 14, 2007 | 05:12 PM
Kingjz's Avatar
cams....
hey guys i dont know much about cams i was wondering like where could i go to look at some and see the price or if there diffrent kinds and what i would be looking for...all help is appericated
Old Sep 14, 2007 | 10:05 PM
Bayer-Z28's Avatar
^ A lot of info in here.. Cam theory and what's what..
http://www.ls1tech.com/forums/showthread.php?t=327734
Check out the following sites for some good grinds..
www.futralmotorsports.com
www.Thunderracing.com
Old Sep 15, 2007 | 03:45 AM
Kingjz's Avatar
hey thanks man that helped me
Old Sep 15, 2007 | 06:41 AM
Greed4Speed's Avatar
Texas-speed.com also has some decent grinds although since you're in TX you'll have to pay sales tax unlike vendors outside of the state.
Where in TX are you? I might be able to steer you to some local shops.
Old Sep 15, 2007 | 10:09 AM
Matt 823's Avatar
that was a really good write up
Old Sep 15, 2007 | 12:56 PM
SSpdDmon's Avatar
http://www.ls1howto.com/index.php?article=23
Old Sep 15, 2007 | 06:57 PM
Kingjz's Avatar
In baytown its like 25 mins outside of houston
Old Sep 15, 2007 | 09:43 PM
I know Baytown. I grew up in Deer Park.
MTI (Motorsport Technologies) is in Houston and G-Force in Pearland are the only 2 shops I can think of down there. You'll find a lot of Houston people post on LS1tech.com in the Texas section and can find more info there.
Old Sep 15, 2007 | 09:47 PM
Kraest's Avatar
Retired
CAM QUESTIONS!!!!!!!!!!!!!!!!!!!!!!!
This place is turning into LS1 Tech.
Old Sep 16, 2007 | 02:37 AM
Bayer-Z28's Avatar
I'm not looking to start anything, but I heard from a couple people that dyno tune on LS1tech that the TSP cams don't really crank out the BEST #'s..
I'm starting to learn that TSP is about PEAK HP #'s and Thunder Racing does a lot of Cam research for different performance BESIDES PEAK #'s. . I found my grind thru Partick G that's going to give me SICK TQ #'s at 2k-4k rpm! Power UNDER the curve is where it's at!!! And it's a VERY streetable cam too!! W/ My soon to come TF heads, I should be at 430rwhp maybe more w/a good tune and about the same TQ.
I'm going to keep this cam as hush hush as I can...
Old Sep 16, 2007 | 01:16 PM
Ya, the Patrick G grind is supposed to be nice, but it is still plenty agressive (and hard on valvetrain) w/LSK lobes IIRC. There are a lot of guys around here running the MS3/4 cams and turning good times so they're doing something right. I personally don't pay attention to the big cams except to look at the overly large lift and durations that people try to run in cam only daily dirvers and stock gearing, but TSP does have some nice midrange grinds which is what I look at since I keep my car as a daily driver and don't care to even try to be the fastest.
Personally, if I was going to get a new cam, it would probably be a custom cam dynamics grind w/a tight LSA. Then again, I just may go w/a sleeper cam with ported heads and just tell everyone the car is bolt-on only.
Old Sep 16, 2007 | 04:01 PM
Bayer-Z28's Avatar
^ Yeah.. The Patrick G torquer Cam I'm looking at has a very mild duration but a lot of lift, 110 lobe sep w/ only 5* of overlap. He said I'll have to custom order that cam.
Old Sep 16, 2007 | 07:58 PM
I read where you could just call TR and tell them you want the Patrick G grind. Short duration on tight LSA's are the grinds Aussies have been running. I read a thread where a guy was getting 400 whp cam only on a short duration cam and it was all in by ~6k rpm.
Only 5*, 0* -2* over overlap doesn't matter if you're trying to be emissions legal. They are all still dirty. The cam I'm running has 2*, but if the EPA cracks down in TX like they're wanting to I'll still have to pull it.
SStrokerAce
N2O Tech
Mar 18, 2006 07:30 PM
1994TransAm
Mar 30, 2004 04:03 PM
stik6shift98
West North Central
18
Jul 1, 2003 11:36 AM
