98 LS1 vs 99-02 LS1
98 LS1 vs 99-02 LS1
What is so bad about the 98 LS1's? And to convert to a 99-02 LS1 would I just need the newer wiring harness and PCM and thats it? I am thinkin about buying a 98 LS1 with T56 setup and putting it in my 96. Any help would be appreciated as well as why I should stay away from the 98. It has 103k. Thanks Mike
IIRC, the issue with the 1997 ~ 1998 LS1s was too many died too soon due to oil pump failures.
Someone else can chime in if this is incorrect.
96 Z28 388 - Heads/Cam/Walbro Pump/42#/Adj Regulator/12.1:1/GMP Timing/Lifters/CC468/Pushrods/1.6RR/Springs/Oil Pan/HV Pump/LT's/X-Pipe/Intake/Throttle Body/Shifter/TR55IX/K&N/Wires/Coil/Underdrive/ES Mounts/MAF/Ram Air/LCA Relo/!CATS/!AC/!AIR/!EGR/TB Bypass/480HP+/-
hmmmmmmmmm so a 98 LS1 with 103k wouldnt be a good idea huh? unless I change out the oil pump you think and install new bearings, then I should be fine, but everyone says the 98 PCM is wacked.
sorry bro, that engine was sold yesterday lmfao, i parted the whole damn motor because I wanna go LS1, I have figured the LT1 out already. Time to get into something new for awhile, dont worry, got an LT1/T56 going into my 280z datsun.
If the oil pump lasted 103k it's probably not going to fail.
98 PCMs are not whack, they are harder to tune and yes a 99 wiring harness and PCM willl work on a 98.
The major reason for not getting a high mileage 97-98 LS1 is that the cylinder liners are thinner so they can NOT be bored if a rebuild is necessary. There's only enough liner for a .005" max hone clean up. If .005 doesn't clean it up then it's sleeves ($$$) or a new block. 99 and up have .010 so a careful machinist could do a minor bore and hone for a rebuild.
