98 LS1 vs 99-02 LS1
Old Sep 16, 2007 | 10:30 PM
Mike96z's Avatar
98 LS1 vs 99-02 LS1
What is so bad about the 98 LS1's? And to convert to a 99-02 LS1 would I just need the newer wiring harness and PCM and thats it? I am thinkin about buying a 98 LS1 with T56 setup and putting it in my 96. Any help would be appreciated as well as why I should stay away from the 98. It has 103k. Thanks Mike
Old Sep 16, 2007 | 10:40 PM
Kris93/95Z28's Avatar
IIRC, the issue with the 1997 ~ 1998 LS1s was too many died too soon due to oil pump failures.
Someone else can chime in if this is incorrect.
Old Sep 16, 2007 | 10:54 PM
96 Z28 388 - Heads/Cam/Walbro Pump/42#/Adj Regulator/12.1:1/GMP Timing/Lifters/CC468/Pushrods/1.6RR/Springs/Oil Pan/HV Pump/LT's/X-Pipe/Intake/Throttle Body/Shifter/TR55IX/K&N/Wires/Coil/Underdrive/ES Mounts/MAF/Ram Air/LCA Relo/!CATS/!AC/!AIR/!EGR/TB Bypass/480HP+/-
If you're making 480 horsepower now, why go with an LS1?
Old Sep 16, 2007 | 10:55 PM
Mike96z's Avatar
hmmmmmmmmm so a 98 LS1 with 103k wouldnt be a good idea huh? unless I change out the oil pump you think and install new bearings, then I should be fine, but everyone says the 98 PCM is wacked.
Old Sep 16, 2007 | 10:56 PM
Mike96z's Avatar
sorry bro, that engine was sold yesterday lmfao, i parted the whole damn motor because I wanna go LS1, I have figured the LT1 out already. Time to get into something new for awhile, dont worry, got an LT1/T56 going into my 280z datsun.
Old Sep 17, 2007 | 06:55 AM
AL SS590 M6's Avatar
Moderator
If the oil pump lasted 103k it's probably not going to fail.
98 PCMs are not whack, they are harder to tune and yes a 99 wiring harness and PCM willl work on a 98.
The major reason for not getting a high mileage 97-98 LS1 is that the cylinder liners are thinner so they can NOT be bored if a rebuild is necessary. There's only enough liner for a .005" max hone clean up. If .005 doesn't clean it up then it's sleeves ($$$) or a new block. 99 and up have .010 so a careful machinist could do a minor bore and hone for a rebuild.
Old Sep 17, 2007 | 08:08 AM
Mike96z's Avatar
oh okay. So is there a specific reason they are harder to tune? So im guessing the wiring harness is the same and all id need is the 99 PCM. Thanks
Old Sep 17, 2007 | 05:13 PM
Dennis93TA's Avatar
harness is diff too. you will need the 99-up harness and pcm or you can re-pin the 98 harness but that takes time and patience.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
