Lsi Throttle Cable Failure
Old Sep 17, 2007 | 02:20 PM
Ed's 01 SS's Avatar
This is a head's up to check the throttle cable sheathing connection where it mounts to the intake manifold bracket, because mine came loose last week while I was driving resulting in a total loss of power. I was lucky to be on a quiet street where I could temporarily repair the cable with a shoe lace so I could get the car home.
I drilled the plastic piece affixed to the cable and attached it to the bracket with a machine screw. I've also fitted a tie-wrap around the unit for added safety. The routing of the throttle cable places a side load on this piece which causes it to fail over time, and the WOT events probably don't help. If this had happened the day before while driving up a mountain near my home the result could have been very bad.
Old Sep 17, 2007 | 04:49 PM
angel71rs's Avatar
Thanks for the heads up, I'll check mine.
Old Sep 17, 2007 | 06:26 PM
9T8W66's Avatar
Mine did this back in `99 when it was about a year old.
I used a Zip Tie to fix it and it's still there. Never had a problem since.
88IROC_Z
Jul 22, 2015 11:38 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
RUNMYTA
Jul 15, 2015 07:50 PM
