500rwhp 408 iron block how hard?
Old Nov 2, 2006 | 02:21 PM
crazyfastbird93's Avatar
Switching to lsx engine, was wondering how many have seen, own, or know of a combo that can yield 500rwhp NA. SO many heads and cams out there for these engines, just need a good start and don't want to do everything twice.
Thanks,
Nick
Old Nov 2, 2006 | 02:45 PM
Eric@Victory Racing's Avatar
VRE 408
ET Performance Cylinder Heads
VRE Spec'd Camshaft
F.A.S.T Intake Manifold
Old Nov 2, 2006 | 04:24 PM
teke184's Avatar
well hell...Kraest made 471rwhp on a stock cube lsx motor...FM15 cam, dart 225 heads, FAST 90/90
i would think you could pick up the extra 30hp with a little bigger cam and better flowing heads on a 408ci block
Old Nov 2, 2006 | 04:35 PM
The car is an automatic, with a 12 bolt, and on a Mustang Dyno, so I was pretty pleased with the numbers.
Old Nov 2, 2006 | 07:52 PM
Greed4Speed's Avatar
The questions is, how much money do you want to spend?
Old Nov 3, 2006 | 03:25 PM
myslowcamaro's Avatar
Originally Posted by Greed4Speed
The questions is, how much money do you HAVE to spend?
fixed.... we all would love to spend more than we have, or at least i know id be spending $20k if i had it right now. eric from vre posted pix of a s88 turbo f-body that was absolutely sick. 1500 hp if i remember correctly. wonder if the 408 block can handle that?
Old Nov 4, 2006 | 07:02 AM
This is the vehicle the S88 turbo is going on. This project will consist of a:
-VRE 408
-4L80e Transmission
-Moser 12 Bolt
-Big Stuff 3
-Custom 10pt Cage
Old Nov 4, 2006 | 08:30 AM
whats the big stuff 3 eric?
Old Nov 4, 2006 | 08:41 AM
The BigStuff3 GEN3 PRO SEFI system is the first programmable “powertrain” control module for“today’s” SEFI, Coil-on-Plug (COP) engines and
electronic controlled transmissions.
It will basically replace the factory pcm, and control the 4L80e transmission. It will also give us alot more tunability for this high horsepower combination.
Old Nov 5, 2006 | 01:35 PM
Kraest's Avatar
Retired
Automatics are going to be much harder to make 500 rwhp through than a 6-speed, but nearly any nasty ETP/AFR/ported LS6 headed, 25x/26x duration cammed, with a sheetmetal intake (or FAST 90/90) should have no problem at all making over 500 rwhp through an auto.
Futral built a Meaux LS6-headed, sheet metal intaked, solid-roller 347 that made 512 rwhp through a TH400, 12-bolt, on 28" slicks.
Mike
Old Nov 7, 2006 | 11:04 AM
SLED28's Avatar
Thanks,
Nick
How come Iron??
Eric what kind of percentage do you find is the difference between mustang and dynojet numbers? 10% ?
Old Nov 7, 2006 | 11:43 AM
AL SS590 M6's Avatar
Moderator
Originally Posted by SLED28
How come Iron??
We've had a few local guys that dynoed on both and the % came out to be 8%.
Old Nov 8, 2006 | 12:34 AM
turbo_Z's Avatar
Seems all the power house LSX motors in GM High-Tech are running with the help of the Big Stuff 3... the poor LT1 is so dead in the water.
ad356
Apr 11, 2015 08:49 AM
Rod Bender
Classic Engine Tech
Mar 18, 2015 08:57 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
Pro Stock John
Aug 1, 2002 09:18 AM
