2002 z28 EGR?
Old Mar 26, 2011 | 11:16 AM
rv93's Avatar
2002 z28 EGR?
From what I had gathered, they removed EGR from the Z28 in 01. But as far as I can tell, my 02 has it. Or, more likely, its something else. Can somebody enlighten me? Theres a hose attached to the forwardmost cylinder on both banks. I have a picture of it on the passenger side.
http://i51.tinypic.com/33ua590.jpg
Thanks for your help.
Old Mar 26, 2011 | 12:13 PM
bluz28's Avatar
Re: 2002 z28 EGR?
That's just the tubes from the Air pump (down below fuse box under the hood); 98-02 all have them. If you want to remove them buy/make some block off plates and plug the hole in the side of the air box.
Old Mar 26, 2011 | 03:03 PM
rv93's Avatar
Re: 2002 z28 EGR?
are there any advantages/disadvantages to removing them?
Old Mar 26, 2011 | 04:14 PM
bluz28's Avatar
Re: 2002 z28 EGR?
It'll clean up the engine compartment,and drop a few pounds if you remove the pump. It will throw a code, but a tuner can delete that.
Old Mar 26, 2011 | 08:47 PM
rv93's Avatar
Re: 2002 z28 EGR?
so its just emissions stuff? alright, ill look into getting rid of it. thanks for your help
Old Mar 28, 2011 | 09:33 AM
AL SS590 M6's Avatar
Moderator
Re: 2002 z28 EGR?
The AIR system pumps fresh air into the exhaust manifolds at certain times to help catylitic converter effeciency. It doesn't hurt performance in any way other than the 4-5lbs that the whole system weighs. Removing it drops and little weight and cleans up the engine compartment.
Noenav
Mar 1, 2019 07:38 AM
k1996z28
Jan 21, 2015 07:22 AM
97SSdude
Dec 31, 2014 07:43 PM
ANDYZ28
Dec 29, 2014 09:13 PM
