2000 silverado 5.3
not that it's very cost effective compared to a cam, but you could throw on a set of 1.85 ratio rockers.
should yield a solid 15rwhp, and increase power all through the power band.
but the cam option is better i think. but there are MUCH better options than the ls6....since it tends to be really peaky on the 5.7L engines...can't imagine wht it would do to a 5.3L
I found some new JBA headers for a 99 02 chevy 6.0 . They don't have the EGR outlet on them, will they work on my oo 5.3 It has the same ball socket on the right side and the flat flange on the left drivers side. I can get the headers for under 100 dollars. can the EGR just be blocked off without sending a code.
The engines are exactly the same external dimensions so physically they will fit and I really can see no other reason why they wouldn't work just fine except for maybe a difference in how the y-pipes might be different.
68camaroboltz
Oct 5, 2015 11:56 PM
