2000 silverado 5.3
Old Jun 21, 2007 | 05:30 PM
  #16
BigBlue95Z's Avatar
Originally Posted by 2xLS1
To get the most out of a tune on a truck you need to run it on 91 octane.
Well if 91(mid) is 5c more, thats 25gal of fuel. So that is $1.25 more per fill up. Lets say I get 1.25 mpg better. That means I will get 31.25 more miles during my tank. Netting about 1.75-2gal of extra gas. With pump prices at $3/gal, that means that I actually saved about $5 every fill up. After 25,500 miles, I've paid for my tune. After 60K, its been a damn good investment.
Old Jun 21, 2007 | 06:11 PM
  #17
2xLS1's Avatar
Maybe it's only .05 more where you are, but it's more like .20~.25 more than 87 around here. 91 is our highest. We have 87, 89, and 91. Trucks come with factory tunes to run on 87.
Old Jun 21, 2007 | 09:49 PM
  #18
lsxprotour69's Avatar
I don't mind running 91 in my truck. It seems to run better and get better mileage on 91 anyway.
Old Jun 21, 2007 | 10:56 PM
  #19
2xLS1's Avatar
Put a timing table in it for 91 octane and it will really wake it up.
Old Jun 22, 2007 | 08:04 AM
  #20
teke184's Avatar
not that it's very cost effective compared to a cam, but you could throw on a set of 1.85 ratio rockers.
should yield a solid 15rwhp, and increase power all through the power band.
but the cam option is better i think. but there are MUCH better options than the ls6....since it tends to be really peaky on the 5.7L engines...can't imagine wht it would do to a 5.3L
Old Jun 23, 2007 | 07:59 PM
  #21
has anyone used a Granatelli MAF or a Big G flash tuner. If so did you like them?
Old Jun 23, 2007 | 08:13 PM
  #22
I found some new JBA headers for a 99 02 chevy 6.0 . They don't have the EGR outlet on them, will they work on my oo 5.3 It has the same ball socket on the right side and the flat flange on the left drivers side. I can get the headers for under 100 dollars. can the EGR just be blocked off without sending a code.
Old Jun 24, 2007 | 06:00 PM
  #23
fasteddie94's Avatar
you'll need to tune out the code.
Old Jun 25, 2007 | 07:27 PM
  #24
So I can use the headers with a tune even though they are for a 6 liter
Old Jun 25, 2007 | 11:26 PM
  #25
errr... I missed the 6.0 part. Couldn't tell ya. I don't know what the difference is in the 6.0 and 5.3 trucks. Check the truck boards.
Old Jun 26, 2007 | 05:53 AM
  #26
AL SS590 M6's Avatar
Moderator
The engines are exactly the same external dimensions so physically they will fit and I really can see no other reason why they wouldn't work just fine except for maybe a difference in how the y-pipes might be different.
Old Jun 26, 2007 | 06:26 AM
  #27
Would the exhaust ports be different from head to head?
Old Jun 26, 2007 | 01:29 PM
  #28
Moderator
Not as far as headers are concerned.
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
68camaroboltz
Oct 5, 2015 11:56 PM
fift5
11
Oct 1, 2015 10:31 AM
pepon214tx
Sep 20, 2015 04:48 PM
scottcba1
Sep 8, 2015 09:52 AM
