2 questions?
Old Sep 8, 2003 | 11:16 PM
coogsLS1's Avatar
2 questions?
Does an aftermarket throttle body look any different from then OEM?
Also, is the mass airflo sensor mod overrated? heard both sides, jw. Cheap mod for some good ponies if its worth it.
Old Sep 9, 2003 | 07:04 AM
teke184's Avatar
i would think on most aftermarket tb's there would be an inscription of the company or brand...makes sense.
you could always measure it. 75mm i think is stock, most aftermarkets are 80mm
and as for the maf mod. it is very arguable. probably only a couple hp if any. you could always lookinto some maf ends, that way if you are not happy you can return them and still have your stock unit.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
