456.4 RWHP absolute 5.3 stage 2's an G5X2
Old Sep 8, 2003 | 06:51 PM
blue2kss's Avatar
I got 456.4 RWHP
407.4 torque
all numbers sae corrected this is an 11-1 all stock bottom end motor
with absolute stage 2 5.3 heads an the G5x2 cam
conservative tune 12.8 to 1 a/f
28 degrees timing
the weather blew at 89% humitity
90 degrees
hopefully after the weather breaks i can go back with a better MAF an
go for a more aggresive tune we were running out of time today
Again i just wanna thank all that helped me with this project
Track times coming soon
these are my current motor mods
Engine
Absolute stage2 5.3 heads,G5X2 cam,CroMo pushrods,Comp 977 springs,titaium retainers,
yella terra rockers,Comp R lifters,LS6 manifold an PCV mod,Shaner S2 TB,K&N FIPK,
,SVO 30 lb. injectors,Rollmaster double timing chain
with torrington thrust bearing,ASP pulley's,Kook's 1x3/4 into 1x7/8's steppeed race
headers with Kook's true dual setup into Magnaflow SS bullets with turndowns,
Mezierre elec.water pump,Coil pak re-location kit with Moroso Ultra 40 race wires,
AC delco rapid fire #12 plugs,ARP harware through-out,Katech ported oil pump,
Optima yellow top battery
here's a link to my sheet an a pull video clip
http://www.fastls1.com/forums/showt...=&threadid=1965
L.I.F.B.A. member # 019
2000 Camaro SS M6 t-top grey leather
other toys - 2001 Suzuki gsx1300r Hayabusa
Old Sep 9, 2003 | 11:23 AM
Shempy's Avatar
Very nice hp number! Why does the torque number not seem right though?
95chwagon
Oct 16, 2015 12:24 PM
fift5
11
Oct 1, 2015 10:31 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
