1, 2, 3, Drive?
When you are driving down the rode running someone from about 60 should you drop it in 3rd or leave it in d?
What are the MPH's for each gear? Are they the same as the LT1 setup of GU5?
The reason I ask, is becuz when I had it in the 3 and nailed it from 70 - I got to 90 pretty quick, but when it hit 5.5K rpm, I started hitting the rev limiter.
KASR
KASR
Originally posted by supersp0rt
you should not be hitting the limiter at 5500. if you have an ls1, your limiter is (or should) set at 6200. you need to have that checked out.
KASR
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
jb4xx
Feb 2, 2015 10:00 PM
