y pipr for lt1
Old Dec 11, 2004 | 02:51 AM
94TA_LT1's Avatar
y pipr for lt1
should i make a 2.5 or a 3 inch y pipe to come off my jet jots? i herd mixed opinions on both. what should i do??
Old Dec 11, 2004 | 04:06 AM
n2oblkz
Guest
Posts: n/a
Re: y pipr for lt1
You should do a 3". If the rest of your exhaust is 3", why not make the Y 3". Unless, your car has been lowered quite a bit and you are worried about ground clearance.
Old Dec 11, 2004 | 05:06 AM
94TA_LT1's Avatar
Re: y pipr for lt1
i only have the pro kit installed. Is the driver's side header supposed to be really close to the floor of the car? I can barely fit my finger between the flange and the car.
Old Dec 11, 2004 | 07:08 AM
n2oblkz
Guest
Posts: n/a
Re: y pipr for lt1
I'm not really familiar with the Jet Hot's, but I think that they are nearly the same as Hooker's. I would have to look at mine and see, I don't know how high my Hooker's fit. As long as it doesn't make contact, which is the main issue, you should be fine.
Old Dec 11, 2004 | 07:10 AM
94TA_LT1's Avatar
Re: y pipr for lt1
yeah, its just that htere is part of the subframe right behind the header collector and it is making it extremely hard to get a y-pipe to connect to the collector.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
