window washer lines
Old Feb 24, 2011 | 09:48 AM
JBirdSS's Avatar
window washer lines
I need to replace the washer lines. Is there line available and unions to join into the existing line? Can this be a hardware store fix or do I have to use 'genuine Chevrolet Parts". Thanks for a reply. JBirdSS
Old Feb 24, 2011 | 07:39 PM
Z28SORR's Avatar
Re: window washer lines
Auto parts would be your best bet. But hardware store would probably work.
Old Feb 24, 2011 | 08:21 PM
JBirdSS's Avatar
Can't find a description or picture of the line routing from the washer fluid tank to the nozzles near the wipers. Anyone have a clue? Where does it branch for the right and left side? Thanks for any reply or help.
Old Feb 24, 2011 | 08:53 PM
moparman's Avatar
On my Firebird, the line runs over the inner fenderwell on the driver's side. Only one line runs to the windshield. The line splits underneath the cowl.
Old Feb 24, 2011 | 09:57 PM
Old Feb 25, 2011 | 10:06 AM
JBirdSS's Avatar
This info is EXCELLENT! Thanks for replies. Shoebox; I searched your site and couldn't find that diagram. For future reference what manual would you recommend for me to buy to begin my research on a 96 SS problem before I decide to take it to a mechanic? The Haynes book didn't have anything on this seemingly easy problem. The washer line in contained inside a large bundle of electrical wiring and the crack would be impossible to find. Replacing the whole line is the only solution. Again, this forum is the best.
Old Feb 25, 2011 | 11:17 AM
moparman's Avatar
If you look at the bundle of wires on the inner fenderwell, you will notice there is only one going to the windshield. That's the washer line.
Old Feb 25, 2011 | 03:49 PM
Z28SORR's Avatar
These are the factory manuals and are the best, but expensive. You can sometimes find them on E-Bay.
http://www.helminc.com/helm/homepage...c=IE-SearchBox
Old Feb 25, 2011 | 04:00 PM
It did not come from my site. It cam from compnine.com.
A used factory manual is the best value and the best manual. Get used from Ebay or other online resellers of used manuals.
Old Feb 25, 2011 | 05:10 PM
JBirdSS's Avatar
Thanks Shoebox and Z28SORR. This is great help and I appreciate your efforts.
Old Mar 4, 2011 | 11:03 AM
JBirdSS's Avatar
For the do-it-yourself guys. I used some PVC 1/4" black irrigation line and 2 easy disconnect unions for the fix of the leaky line. The stock line is a few thousandths smaller than the 1/4 dia. new line and wrapping it with about two rounds of electrician's tape made the install tight enough for the unions to be completely drip free.
The quick connect coupling is made by WATTS PL-3000 1/4" OD purchased at Lowes.
DSMKilla
May 26, 2015 10:10 PM
warmeck
Feb 2, 2015 12:44 AM
Jazsun
Dec 29, 2014 12:14 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
