Window Regulator Spring?
Old Jun 14, 2012 | 07:25 AM
mikeZ2878's Avatar
Every time I close the door the spring falls off......is there a clip that holds the spring in place? Here is what it looks like
Old Jun 14, 2012 | 11:02 AM
mrmint69's Avatar
Re: Window Regulator Spring?
Had this happen on a Buick and could never get it it to stay on. I decided that if it was a problem, I would replace the regulator and never had to. I think the problem is it nneds to be on a certain way and I could never get it back the way it was originally. It is under a lot of tension when on correctly, I think.
Old Jun 15, 2012 | 01:52 PM
I believe the spring being wound to the proper tension holds it on.
Old Jul 7, 2012 | 12:53 PM
mikeZ2878's Avatar
Thanks for the help. I appreciate it. The spring fell off after I put the new motor in. The window goes up and down fine without the spring in place.
Old Jul 7, 2012 | 01:23 PM
The spring helps the motor. Without the spring, the motor may not last near as long.
Old Jul 7, 2012 | 02:24 PM
mrmint69's Avatar
I tried to put it back on mine. I work on these all the time and had no luck. It can be done, but years later and motor still works like new. I decide to replace it, before I would spend any more time working on it.
Old Aug 5, 2012 | 12:32 AM
mikeZ2878's Avatar
to the top
Old Aug 17, 2012 | 12:27 PM
mikeZ2878's Avatar
to the top
Old Aug 17, 2012 | 03:11 PM
mrmint69's Avatar
It appears no clip is needed and the tension is what holds it. Must be taken out and installed. Very hard to do and get the tension correct, but pretty sure you can do it.
Old Oct 31, 2012 | 12:32 PM
mikeZ2878's Avatar
I fixed it
Old Oct 31, 2012 | 04:25 PM
Originally Posted by mikeZ2878
I fixed it
It could be awfully helpful to the next person that finds this thread with a search if you would elaborate a little more...
Old Nov 2, 2012 | 10:51 PM
mikeZ2878's Avatar
My bad.....you have to twist the spring and push it in till it locks in place
Old Nov 10, 2012 | 06:06 PM
Jeffs1997's Avatar
It is easy to do, this was a 82 vette regulator. Just slide spring about 1/2 way down into the center slot, then clamp onto other end with vice grips (but not to tight) then bring the spring around to the other stud so that it is above it and then just tap it down into place with a hammer. Takes 30 seconds to do.
Keenan
Jan 19, 2023 12:24 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
Feb 2, 2015 12:44 AM
