window noise issue - neeed a little help
Old May 26, 2018 | 04:37 PM
scottpdx2010's Avatar
Hi all. I have a 1996 Formula Firebird. The car is nice stock shape. There is one problem i was looking for some help on. The driver side window has a annoying problem. the window is a bit loose and it sometimes rattles in the part down position.
I took the door panel off to look at the window. I did tighten the stabilizer tight to the window, but that did not fix it.
At a closer look i saw the support gm #10198211 with the plastic t looking part was broken. I did get one of those, also i have (2) front window plastic stabilizer gm # 10165402 i read is a common problem with that symptom. I am not real great at this, but i can do some repairs on my own. I need a little help as to how di i change it?
Do i need to remove the window to do this? or can it be none with just the door panel off?
I would appreciate any help i could get
thanks in advance :Scott
Old May 26, 2018 | 05:12 PM
Re: window noise issue - neeed a little help
Shoebox has a procedure for adjusting the windows. Not sure if it addresses this specific problem, but worth a look:
Adjust Door Window
Old May 27, 2018 | 09:02 PM
thanks Injuneer, that helped with the stabilizers, but my problem was not solved. it is in the support (that is broken, or the plastic stabilizers. )
looking for information on those parts.
larryndog
Jul 20, 2006 12:31 PM
CAMARO16
Jul 3, 2006 02:46 AM
ReaverZ28
Apr 7, 2005 10:27 PM
naztyz28
New England Area
Mar 27, 2003 10:09 PM
corkss
Mar 9, 2003 01:53 PM
