Neeed Help Asap
Old Apr 6, 2005 | 09:41 PM
ReaverZ28's Avatar
Neeed Help Asap
Car has been running well till now. when i start it , it sounds realy rought and the car shakes and it tends to die if i dont push on the accelerator. after about 1 min of this stumbling its like the motor catches on and i get power an it sounds normal im wondering if i need new spark plugs? thanks in advance.
Old Apr 6, 2005 | 10:04 PM
ReaverZ28's Avatar
Re: Neeed Help Asap
help please
Old Apr 6, 2005 | 10:10 PM
MeanGreen97Z's Avatar
Re: Neeed Help Asap
That, plug wires, or the optispark.
Old Apr 6, 2005 | 10:17 PM
Z28LessTX's Avatar
Re: Neeed Help Asap
mine had that issuse awhile back but i ended up haveing a loose wire from the msd box to the coil, check all your wires, plugs, and opti spark like the others said
Old Apr 7, 2005 | 10:27 PM
ReaverZ28's Avatar
Re: Neeed Help Asap
turns out its my fuel pump when we checked fuel pressure after about 4 min instead of the 40-47 psi i had 18.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
