Window Motor Speed
----Yeah I hope my passenger side is just slow. My driver`s side goes right up but the passenger side takes a bit longer and doesn`t go all the way up unless I open the door (because of the resistance from the rubber seals.----
Thats the exact same thign mine does...thats what i hoped replacing it will fix.
Bill
Bill
Mine wont work with the engine off and on acc anymore, they are just too slow.
I lower them one at a time when I can, my driver one is slow going down, passenger one is slow going up.
I'd remove the door panal and spray WD-40 on the track/rollers but I'm affrade I'll damage the door panal and not be able to get it back on properly. I once removed the window switch and never got it back correctly in the door.
Any advice do I dont breake any clips?
Don't worry about breaking your door panel, it's very simple. All you need is a small pry bar and a phillips head screwdriver.
shoeboxs' site under R&R window motor shows step by step with pictures on removing the door panel.
Link
The clips are pretty tough cookies...
Link
