Windage?
Old Jul 21, 2006 | 09:03 PM
JakeRobb's Avatar
Super Moderator
Question Windage?
Can anyone explain windage as it applies to engines?
This is all I know:
http://en.wikipedia.org/wiki/Windage
I know this isn't F-body specific, but it didn't apply to any particular engine, and I don't think it qualifies for advanced tech. If it should be somewhere else, I apologize.
Thanks!
Old Jul 21, 2006 | 09:27 PM
MyShibbyZ28's Avatar
Re: Windage?
Wind is a force acting against the car, causing more pressure and friction against the car. Inturn makes the engine work a little harder. More aerodynamic the shape of the car is, the less the engine has to work.
Is that what you wanted to know?
If nothing else, think of it like riding a bike with the wind, then against the wind.
Old Jul 21, 2006 | 09:33 PM
JakeRobb's Avatar
Super Moderator
Re: Windage?
Not wind. Windage. Engines have windage trays. I think it has something to do with the friction of turning the crankshaft amidst all of the oil.
Old Jul 21, 2006 | 10:48 PM
s10er8's Avatar
Re: Windage?
It is, oil wraps all up on the crank and flies everywhere and at high rpm's it flings it off and causing it to splash back up on the crank
Old Jul 22, 2006 | 07:05 AM
JakeRobb's Avatar
Super Moderator
Re: Windage?
Okay, so what is the function of a windage tray?
Old Jul 22, 2006 | 08:12 AM
Re: Windage?
To keep the oil off the crank, and to keep the "wind" from the crank from working the oil up into a froth.
Old Jul 22, 2006 | 08:20 AM
Dave89IROC's Avatar
Re: Windage?
The strict definition of windage is the power loss caused by the friction of the oil in the engine coming into non-lubrication contact with the moving parts inside the engine. For the most part, this is oil splashing against the counterweights of the crank as it spins. If there is poor oil control inside a race engine, windage can cause some pretty significant power loss. First, as rpm increases, the amount of power loss for a given amount of windage increases dramatically. As a liquid, it's the same concept as water in a swimming pool providing little resistance if you slowly dip your hand into it. The feeling of resistance becomes much different if you do a belly flop off the high dive into that same pool.
good info here
http://www.circletrack.com/techartic..._pans_windage/
Old Jul 22, 2006 | 10:38 AM
JakeRobb's Avatar
Super Moderator
Re: Windage?
Originally Posted by Dave89IROC
Perfect! Thanks.
HectorM52
Jul 30, 2017 11:46 AM
dfarr67
Apr 10, 2015 07:44 PM
thewinner
Dec 4, 2004 02:54 PM
ZDriver96
Jun 26, 2004 12:38 PM
Toph
Jun 17, 2003 09:40 PM
