A/c Help
Old Jul 20, 2006 | 04:03 PM
partsguy's Avatar
A/c Help
has anyone had this problem with your a/c.its got freon.my snap-on scanner says its on and working.but no cold air just heat damn texas heat.anyone seen this before
Old Jul 21, 2006 | 06:56 AM
M5camaro's Avatar
Re: A/c Help
This is happening with my car as well! The unit is coming on, I'm 99% sure it has a charge, but all I get out of the vents is hot air!
Old Jul 21, 2006 | 05:21 PM
OBE1 95Z28's Avatar
Re: A/c Help
Is the compressor turning? The scanner might see the PCM command to turn on the compressor but if your wiring to the compressor or connector at the compressor are bad, the compressor may not be running.
Old Jul 22, 2006 | 03:59 PM
FastrDamnit!'s Avatar
Re: A/c Help
Usually you can hear the AC clutch engage within the AC pulley a split second after turning the AC on. Usually a faint click.
If it is engaging I'm guessing you just have a bad freon leak (usually the seal on the front of the compressor is the first place to look). Take it to your local AC shop and have them scan with a freon 'sniffer' or dye test for leaks.
I just went through this whole mess on my wife's car, ended up getting a used compressor at a local junkyard. AC now works great.
magman
Apr 15, 2016 03:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
MikeWhitener
Aug 2, 2015 06:17 PM
timmy39120
May 8, 2015 11:41 AM
alphaauto
Feb 5, 2015 05:25 PM
