will my fuel gauge work without PCM?
Old May 28, 2007 | 04:39 PM
mdacton's Avatar
just wondering....don't have a PCM anymore
Old May 28, 2007 | 06:54 PM
The PCM has nothing to do with the fuel gauge AFAIK.
Old May 28, 2007 | 06:58 PM
mdacton's Avatar
o.k.
What else will work? nothing?
water, amp, oil? If not then I need to order some gauges asap
Old May 28, 2007 | 09:10 PM
Only the tach and the speedo are driven by the stock PCM. Both can be connected without the PCM. Coolant, system volts and oil pressure are direct wired from sensors, not the PCM.
Old May 28, 2007 | 09:17 PM
mdacton's Avatar
so fred I have an old harness.......I can just find the wires and plugs I need and hook up the other gauges? If so that would be good for now, I don't need the tach or speedo
Thanks for the help guys
Old Oct 30, 2007 | 06:52 PM
mdacton's Avatar
shoebox hope you can help me again....
What did I need to do in order to make the stock alt. work? I know you said wire a resistor to a switched 12v but how much was it?
If anyone can help thanks
Old Mar 10, 2018 | 02:28 PM
Villin's Avatar
Re: will my fuel gauge work without PCM?
new sending unit Gage won't work no pcm can play
Old Mar 10, 2018 | 02:38 PM
Could you provide basic info, like the year of the car? Could affect the answer. And not sure what "no pcm can play" means.
In the meantime, if it's a 93-97, read this:
Courtesy of Shoebox
4th Gen LT1 F-body Tech Articles
Old Mar 10, 2018 | 08:57 PM
Villin's Avatar
I have a 98 Camaro with stand alone pcm and harness no factory pcm will my gas Gage work
Old Mar 11, 2018 | 12:41 PM
NO
This is why we need to know the basic info. Up through 1997 the level sensor is wired directly to the fuel level gauge. In 1998 they changed the setup, and the level sensor signal requires the PCM to interface with the fuel level gauge. Generally, it makes sense to keep the stock PCM (in addition to the aftermarket ECU) for functions like the speedometer, tachometer, and starting in 1998 the fuel level gauge.
Garcia5
Jul 7, 2022 06:51 PM
sdn1997rs
Dec 30, 2014 08:30 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
Jul 4, 2005 05:00 PM
