Where can you double check the window VIN
Old Aug 7, 2006 | 09:45 AM
john-e-boy's Avatar
I'm looking at buying a 97 SS and would like to be sure that it is a real ss. I verified through SLP that the VIN was infact an SS but would like to verify that the VIN in the window wans't changed.
Where else can you find VIN #'s?
Any other ways to tell it a real SS other that SLP and RPO code R7T?
Old Aug 7, 2006 | 10:00 AM
Bow94z's Avatar
Re: Where can you double check the window VIN
RPO code sticker in glovebox, i think it's on the drivers door aswell
Old Aug 7, 2006 | 10:28 AM
Stephen 87 IROC's Avatar
Attached to anything like glove box doors can always be changed. You need to find one of the decals that's attached to sheet metal.
You'll have to do some disassembly to find them. The easiest is the decal on the driver's door but then doors can also be replaced unless the decal is on the door jam.
There should be one on the underside of the deck lid. You need to remove the plastic to see it. Deck lids can be replaced.
There should also be VIN decals on the inside of the rear fenders behind the tires. Pull out the spare tire and remove the plastic. These VIN decals would be hard to replace since they're attached to the main body sheetmetal.
Old Aug 7, 2006 | 12:57 PM
Craddock's Avatar
I think you can just call SLP and ask them if it is an real SS because I'm pretty sure that they made all the 96 and 97 SS's.
Old Aug 7, 2006 | 03:47 PM
A portion of the VIN is on the engine, and on the tranny.
Shoebox has photos of the location:
http://shbox.com/1/block_vin.jpg
grgguy
17
Feb 23, 2015 07:57 PM
ModdedNerd
Jan 29, 2015 07:23 PM
squarehead
Jan 15, 2015 07:02 PM
Rich_z28
Aug 29, 2002 10:44 PM
Caps94ZODG
Aug 5, 2002 06:31 PM
