wheel noise
Old Nov 15, 2007 | 04:35 PM
gilg99ss's Avatar
wheel noise
When I apply the brakes at a slow speed I hear a wierd noise kinda like the tire is rubbing on something. It also does it when i am turning. Could it be the tire brand. I have the original rims and tire size 275/40.
Old Nov 15, 2007 | 06:24 PM
Kraest's Avatar
Retired
Not LS1 tech. Moving.
Old Nov 15, 2007 | 06:47 PM
gilg99ss's Avatar
what do you mean? where should have i posted this at?
Old Nov 15, 2007 | 07:29 PM
Kraest's Avatar
Retired
Please read the sticky about posting in the LS1 Tech section before posting in aforementioned section.
General wheel and brake questions do not belong there.
Yes, you may have a very little rubbing with 275s on the front.
Mike
Old Nov 15, 2007 | 08:50 PM
87slyroc's Avatar
id say start simple. look at the back of the rotors to make sure that your pad isnt gone. ive seen that more often then not. if thats fine, then check the side wall of your tires, the evidence should be easy to find if it is rubbing. other than that, there are a handful of suspension components that make "weird" noises. but without hearing it, not much more i can offer...
Old Nov 15, 2007 | 11:48 PM
Drive with a wall on the driver's side of the car, and try and determine if the noise is coming from the front or rear of the car. You've got to narrow it down a bit.
akwa
Apr 5, 2015 05:09 PM
Fatdog2
Feb 12, 2015 12:24 PM
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
squarehead
Nov 21, 2014 08:02 PM
