whats the best way to push start a 6spd?
Old Oct 29, 2004 | 07:57 AM
  #16
J3ff's Avatar
Re: whats the best way to push start a 6spd?
i did this once, and it seemed like my computer didnt come on 100 % ..... the engine was running...but the second i gave gas or anything it stalled out...and it was idoling at like 1900 rpms..and NOTHING inside the car was working. sorta freaked me out
Old Oct 29, 2004 | 12:33 PM
  #17
rncotton's Avatar
OK, funny story time.
When I was younger, my dad owned this Fiat Spyder, which was a PITA and in the shop more than we drove it. It wouldn't start one day, so he got my sister to drive her Olds Cutlass Supreme and push him down the road so he could pop the clutch and get it going. (Pushing by hand hadn't gotten it started, so he thought he needed to go faster, hence the reason for getting my sister to push him)
So off they go down the road, after a short distance, he realized that the Fiat just wasn't going to start, so he started waving his hand at my sister to tell her to stop. She, however, thought he meant to go faster, so she did.
Every time he waved, she thought he wanted to go faster, so she would speed up. The faster he waved, the faster she went.
Can you just imagine seeing a '78 Olds Cutlass Supreme pushing this little Fiat Spyder down the road at 50 MPH? ROFL !!!
My dad finally sold that car to the mechanic that kept fixing it.
Old Oct 30, 2004 | 06:52 PM
  #18
funina91ss's Avatar
your local ford guys will be glad to give any gm man a push.
Old Oct 31, 2004 | 09:17 AM
  #19
MrDude_1's Avatar
Originally Posted by TW95Z
I agree with Shoebox. My Grandfather taught me to push start the tractor on the farm by telling me to put it in high gear and let the clutch out once it was rolling. I took off down through the pasture just fine, but I still have to laugh when I remember looking back and seeing him and my sister bouncing all over in the two wheel cart I was towing behind. I forgot that part about putting the clutch back in once the engine started.
its all about engine speed.
think about this... on a tractor, you can start in most of the gears from a stop. if you had it in the ultra low first when the clutch gets poped out, you're trying to spin the engine really fast. meanwhile if you stick it in too high of a gear, when you pop it, the engine is still spinning too slow to start.
most of the time with street cars, you popstart it in first. if it has really low gears you may be able to start it in 2nd.....
Old Oct 31, 2004 | 10:18 AM
  #20
BS. You don't need that much speed to crank the engine. There is a tremendous amount of gear reduction in first gear. Using a higher gear, there is less chance you will loose traction on a low traction surface, as well (someone already mentioned dragging the tires). The engine will spin more easily and smoothly in a higher gear. 3rd gear or higher will easily start the engine, not to mention being much kinder to your drivetrain.
Amshnock
14
Jan 18, 2015 11:47 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
blac94Z
Nov 24, 2014 07:12 PM
