What to use to loosen a bolt?
Old Oct 6, 2005 | 01:04 PM
YARDofSTUF's Avatar
If it matters its the bolt for teh panhard rod on the drivers side.
Tried using oil so far, cant get the thing to move at all.
Old Oct 6, 2005 | 01:10 PM
nfa's Avatar
nfa
Re: What to use to loosen a bolt?
I had a hell of a time getting this bolt off, too.
Use a wire brush to clean up the threads. Hit it up with PB blaster the day before you start working on it. If you have access to a torch, hit it up with some heat. Then get a big breaker bar, and go to work on it!
Old Oct 6, 2005 | 01:12 PM
Z28SORR's Avatar
This is a large high torque bolt, are you using a long 1/2 drive breaker bar? A pipe extension on a short bar works to.
Old Oct 6, 2005 | 01:28 PM
YARDofSTUF's Avatar
I'm using wrenchs, regular wrenchs.
Whats PB blaster and what is a breaker bar? Just put a pipe over the wrench?
Old Oct 6, 2005 | 01:30 PM
AW/whiteZ-28's Avatar
PB blaster is penetrating oil and yea just put a pipe over the wrench.
I just had to use my muscles *flexes*
Old Oct 6, 2005 | 01:32 PM
YARDofSTUF's Avatar
Wanna drive to CT muscleman? LOL
Old Oct 6, 2005 | 01:34 PM
Z28SORR's Avatar
What is a breaker bar?
This: http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Oct 6, 2005 | 02:50 PM
YARDofSTUF's Avatar
Got some gunk penetrating oil and a couple of pipes, home depot didnt have PB blaster and i wont be paying 90 bucks for a breaker bar... I hope lol
Old Oct 6, 2005 | 02:53 PM
nfa's Avatar
nfa
unless you make a living wrenching on cars, its not worth paying 90 for a breaker bar. you can get away with a 20 dollar bar. hit the bolts up with the penetrating oil a couple of hours before you decide to attempt taking it off.
Old Oct 6, 2005 | 04:36 PM
lt11997's Avatar
Use a breaker bar or a piece of pipe over your wrench. If that doesn't work you can heat the bolt up.
Old Oct 6, 2005 | 08:14 PM
YARDofSTUF's Avatar
Got it, that gunk stuff made it pretty easy, 4 bucks of pipe adn a socket wrench got it after that.
Thanks.
Old Oct 6, 2005 | 10:31 PM
If you use a socket, it should be a 6 point.
Old Oct 7, 2005 | 02:14 AM
YARDofSTUF's Avatar
It was, but why is that important?
Old Oct 7, 2005 | 04:19 AM
Lower's Avatar
A 12 point has less contact area, and thereby a better chance of rounding the nut or bolt head.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
Catmaigne
Dec 25, 2014 12:16 PM
