What size rivets for window?
Old Nov 29, 2004 | 03:49 PM
bad93z's Avatar
I searched the site and found lots of info on the rivets/nuts&bolts for the window motor, but none for the motor bracket. I made the mistake of thinking I had to remove the whole power window assembly to change my window motor I got everything else back together, but I cannot find a rivet that properly fits the holes in the door for the motor bracket
Old Nov 29, 2004 | 04:08 PM
TraceZ's Avatar
Re: What size rivets for window?
Those rivets are available at you local GM parts counter.
I have a few leftover from a past job I did. I think they were just over $1 each. The rivet gun required to install them is pretty hefty! Many models run on compressed air. Any auto glass repair shop would have one, and probably the rivets too. You might just want to drive it over with the door panel removed and give someone some cash to shoot the rivets in for you.
Old Nov 29, 2004 | 07:07 PM
bad93z's Avatar
Thanks!
Old Nov 29, 2004 | 10:24 PM
KPZ-28's Avatar
The window regulator bracket takes a 1/4" diameter peel- type rivets. Napa part number 665-2438. Put something between the inside door panel and bracket to cushion the flying nail head of the rivet when it breaks off and mushrooms with a bang! It also requires a big rivet gun to handle that size of rivots.
Old Nov 30, 2004 | 02:29 PM
Z28SORR's Avatar
Or just use the nuts and bolts, 1/4" dia. pan head with lock nuts.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
DSMKilla
May 26, 2015 10:10 PM
QuickSilver02
Apr 7, 2015 11:12 AM
warmeck
Feb 2, 2015 12:44 AM
