What resistor to step 12 volts down to 2?
Im not sure what ohm to use. Does anyone have the calculation for figuring this out? Google is failing me...
Im hooking up LED light indicators on some on my switches (fan, fuel, ex).
EDIT: Nevermind. Found my answer here http://www.theledlight.com/ledcircuits.html
LED calculator
http://metku.net/index.html?sect=vie...calc/index_eng
LED calculator
You don't need, or want to use a voltage divider to power an LED. Again, LED's are current controlled devices. You limit the current to the LED through a series resistor.
Using ohms law you can calculate the resistance needed (i.e. 13v/25mA = 520ohms). Led's have a rated forward current you should shoot for.
Being semiconductors, LED's do not have a linear relationship of voltage to current as many other things do. A small overvoltage percentage could result in double the current flow or more, burning out the led.
http://www.radioshack.com/product/in...ductId=2062569
WobblySausage
Oct 7, 2015 02:44 PM
jackpawt883
Sep 10, 2015 08:53 PM
